Metro A+ Crown Wheel And Pinion Into Remote A 22G1128
6 replies to this topic
#1 johnv
johnv
  • 499 posts
  • Local Club: FDMC
Posted 15 June 2022 - 01:58 PM
Will a metro CWP fit into a remote diff casing from a 998 cooper 22G1128 box?
thanks
title should read remote .. it was changed to remove without my consent
Edited by johnv, 15 June 2022 - 02:00 PM.
#2 imack
imack
  • 2,372 posts
Posted 15 June 2022 - 02:13 PM
An A+ crown wheel and pinion will fit but may require modification to the mainshaft bearing retainer depending on the ratio chosen.
I fitted a 2.9:1 CWP to an 22g1128 and had to grind clearance into the bearing retainer.
#3 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 15 June 2022 - 02:16 PM
I seem to remember it should fit fine.
Only issue is that if you have a 2.9 or 2.7 ratio the pinion gear bearing retainer needs to be ground out to allow for space because the gear is so big.
The reason I say 'I remember it should' is that I did it when I was 17 on my 1275GT ....just 40 years ago now!
#4 MiniJosh92
MiniJosh92
  • 1,711 posts
Posted 16 June 2022 - 06:19 AM
http://www.guess-wor...play.htm?id=148
#5 nicklouse
  • 18,998 posts
Posted 16 June 2022 - 06:35 AM
thanks
You mean auto correct on your phone/pad did it for you.
you can go into full edit and change the heading. Just going into edit does not give access to the heading to edit it.
but as said yes they are interchangeable like for like. But the ones with the larger pinion gear may need some modification.
#6 Spider
  • 15,684 posts
Posted 16 June 2022 - 07:34 AM
Fixed.
#7 johnv
johnv
  • 499 posts
  • Local Club: FDMC
Posted 16 June 2022 - 08:02 AM
yes Nick ;)
