Left Rear Reverse Light Always On When Headlights Are On?
29 replies to this topic
#1 jezjsa
jezjsa
  • 90 posts
Posted 16 June 2022 - 10:28 AM
Hi.
as the title suggests... the left rear reverse light comes on when headlights are turned on. Anyone any 'bright' ideas? This is 'hopefully' the last thing to fix before i can get it MOT'd :)
#2 KTS
KTS
  • 2,423 posts
Posted 16 June 2022 - 10:49 AM
..just when the headlights are on ?  or when sidelights and/or headlights ?
i'd suspect a bad/poor earth to the rear light cluster...
#3 andyapanel
andyapanel
  • 624 posts
Posted 16 June 2022 - 11:45 AM
The bullet connectors at the front often become manky. I would clean those first, then check other earths.
Good luck
#4 jezjsa
jezjsa
  • 90 posts
Posted 16 June 2022 - 11:47 AM
Ah good point, ive not looked when just side lights, i'll check later tonight.
#5 jezjsa
jezjsa
  • 90 posts
Posted 20 June 2022 - 07:43 PM
ok so bit more of an update on this...
so the left reverse light is coming on when you turn on the ignition.
i've added a temporary black wire from the light housing itself back to the negative battery just to see if it was a bad earth, but that has done nothing.
Also, tried using the connector from the right side light housing and pulling it across to use on the left hand side and still the reverse light lights up!
When i turn on the sidelights or main beam, the reverse light goes off now.
Anyone any more suggestions - greatly appreciated...
#6 sonscar
sonscar
  • 2,998 posts
Posted 20 June 2022 - 08:25 PM
Wiring melted to exhaust near gear shifter?Steve..
#7 jezjsa
jezjsa
  • 90 posts
Posted 20 June 2022 - 09:14 PM
Wouldn’t that make both reverse lights come on? Rather than just the left hand side?
#8 stuart bowes
stuart bowes
  • 2,113 posts
Posted 20 June 2022 - 09:15 PM
surely it's got to be a short between the side light or other switched live (green wire?) to the reversing light on that side
#9 mini-mad-mark
mini-mad-mark
  • 850 posts
  • Local Club: northants wot no brakes
Posted 20 June 2022 - 09:25 PM
Is the right reverse light working as it should because in theory they are connected so whatever happens to one should happen to both.
#10 mini-mad-mark
mini-mad-mark
  • 850 posts
Posted 20 June 2022 - 09:28 PM
Sorry should have added - maybe the problem is with both lights but if the bulb is gone on the right hand side you might have a problem that is simpler i.e. the reverse light switch is badly adjusted
However doesn't explain why it goes off when the lights are switched on....
For what its worth I would say that electrical issues are the hardest to analyse/describe/solve remotely like this
#11 jezjsa
jezjsa
  • 90 posts
Posted 20 June 2022 - 09:41 PM
not sure if this helps but I have a spare light cluster for the left side, and it does exactly the same thing, eg the reverse light on the left stays on. But goes off when side or main lights switched on.
#12 jezjsa
jezjsa
  • 90 posts
Posted 20 June 2022 - 09:48 PM
I’ll check your theory tomorrow, I have the fuel tank sat in the middle of the boot as I had to gain access to the back of the light, and it has no fuel in it…. So I’ll refit, refill … then start up, stick in reverse and check. I also rigged up a big mirror behind the car so I could see what the hell the goths were doing! :)
I’ll try stopping the reverse bulbs around too and see what, if any, effect that has.
cheers for all the advice, I know electrical issues are a pain over a forum rather than in person, but thanks all the same guys.
#13 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 21 June 2022 - 08:38 AM
You have more than one?
#14 stuart bowes
stuart bowes
  • 2,113 posts
Posted 21 June 2022 - 10:03 AM
I was going to ask that, I couldn't remember from when I dismantled mine but cars of that sort of age didn't tend to have 2 did they
#15 sonscar
sonscar
  • 2,998 posts
Posted 21 June 2022 - 10:27 AM
Its the internet,you often only get half the story,confusion exists,the fault sometimes is a feature.You explain something and because you know how to do it sometimes does not translate well to someone else etc,etcSteve..
