Overheating Issue
4 replies to this topic
#1 curlyfella
curlyfella
  • 51 posts
  • Local Club: Manchester Mini
Posted 16 June 2022 - 12:58 PM
Attached File  Fan.jpg   49.35K   0 downloadsHi All
Replaced radiator, water pump, and pipes and fan last year, but car has been off the road with other issues.
Just got it back up and running and its overheating again.
Only went out for a short run and heating guage went to the red very quickly.
Checked to see if the radiator was full and nearly was so topped up.
Im not sure if i have put the fan on the wrong way round???
Any ideas???
Edited by curlyfella, 16 June 2022 - 01:06 PM.
#2 Lplus
Lplus
  • 990 posts
Posted 16 June 2022 - 01:20 PM
The fan looks right way round.  Maybe sticking or broken thermostat?
#3 sonscar
sonscar
  • 3,198 posts
Posted 16 June 2022 - 01:29 PM
Have you any signs other than the gauge that it is actually overheating?,Steve..
#4 Quinlan minor
Quinlan minor
  • 1,325 posts
Posted 16 June 2022 - 01:45 PM
If the "heating guage went to the red very quickly", I would suspect a thermostat stuck shut.
Run it up to just above normal, shut down and check the top hose. Is it hot?
If not, confirms thermostat problem.
Liberally coat the thermostat housing studs with releasing fluid and get yourself a new one and the necessary gaskets.
Edited by Quinlan minor, 16 June 2022 - 09:01 PM.
#5 Spider
  • 15,684 posts
Posted 16 June 2022 - 08:14 PM
Check that it is in fact overheating. If you are only going off the gauge, the gauge itself (or some part of that system) may well be faulty.
