I am getting a classic mini clubman estate back to working order and have run into a problem with the front suspension. The cones are badly in need of repair and the car rides on the bumpstops. I am replacing cones and trumpets with hilos. The front right hand side went fine and the car is sitting up a few inches higher. I am having a problem with the front left hand side.
I removed the nuts holding the pivot pin on and the diamond shaped locking piece in place. No amount of banging, levering, liquid wrench, or heat will get the pivot pin to move so I can get the control arm out. I suspect the washer on the front of the assembly is rusted to the tower. All the guides I can find deal with removing the bearings and generally skip over getting the pivot to move.
What is my next step here? Cut out the back of the pin with a grinder? Is there a ball joint remover with enough reach to push it forward from the back?
