How Can I Make Door Seals Water Tight?
Posted 24 June 2022 - 10:28 PM
coming in whilst it’s raining?
Posted 25 June 2022 - 07:16 AM
Posted 25 June 2022 - 08:18 AM
I had a similar problem with my boot lid. I used a strip of paper about 5cm wide and opened and closed the boot lid whilst moving the paper along, to see where it gripped. Where it did grip, it was surprisingly tight, but in one corner it just slipped out easily.
I bent the metal lip that the rubber sits on, until it gripped the paper.
Posted 25 June 2022 - 12:05 PM
Gaffer tape
... are you really sure it's coming past the door seals? Minis have many more ways of leaking:
From the interior of the doors if they aren't sealed behind the door cards
Check strap boots
Air vents
Under wing ducting
Scuttle closing panel corrosion
Windscreen seals
Posted 25 June 2022 - 03:25 PM
This is a page from an original BMC Dealership document from 1959-60 for adjusting an early Mini door to fit better with a length of wood and some brute force.....if you try it no guarantee of the end result though and at your own risk!
Edited by mab01uk, 25 June 2022 - 03:28 PM.
Posted 25 June 2022 - 04:04 PM
It`s not uncommon for the rear light rubbers to perish and leak water through the boot and onto the floor pan which then finds it`s way to the front floor.
Toilet paper slipped under the bottom of the door cards will tell you if it`s the doors
Posted 26 June 2022 - 08:14 AM
Shooter
