Pscan Diagnostics Mpi Result - Need Help
1 reply to this topic
#1 nont_za
nont_za
    Starting My Mini Up
  • 3 posts
Posted 29 June 2022 - 02:15 PM
Hi There, I just plugged in Pscan on my Mini MPI. All stock without any modifications and "cold start". The result are on the pictures. It seem that there something wrong with
- Coolant temperature
- Oil temperature
- Intake air temperature
Not sure are there any others. Your help would be much appreciated.
291092586_10225142383321361_518428762086
291181416_10225142383601368_871832195494
291364130_10225142383761372_475046179406
#2 tmsmini
tmsmini
  • 730 posts
  • Local Club: MOASF
Posted 02 July 2022 - 05:20 PM
The MEMS 2J as used in the Rover Mini does not monitor ambient temps or oil temps.
Many readers look for all the values the MEMS 2J is capable of storing and report on them.
Intake or inlet temp is monitored, but appears to be reading in the pictures above, do you have other errors showing a problem? It may be reading low(56) if the engine has been running for any length of time depending on the outside emp..
Edited by tmsmini, 03 July 2022 - 01:58 AM.
