Are Grilles Different Lengths
Posted 30 June 2022 - 06:10 AM
But the top moustache rail used to almost touch the moustache ends on the old one, the new one there is a inch difference.
I have fitted it now but it's super tight and actually touches both headlights. So if it rattles about I will have to do something about it.
Question, are grilles different lengths as well as different styles? Everything non-mk1. Thanks
Posted 30 June 2022 - 06:22 AM
Only MK1 had the Moustache part.
which part are you on about? The part on the bonnet? There is adjustment in the āCā ends.
Posted 30 June 2022 - 12:56 PM
Posted 30 June 2022 - 12:59 PM
The top 'moustache' rail should be the same width as the bonnet. The grilles were all the same size Mk2/3 onwards.
Do you perhaps have cheap pattern copy grille from an unknown supplier? There are lots of poorly fitting copy Mini parts for sale online....
Edited by mab01uk, 30 June 2022 - 01:01 PM.
Posted 30 June 2022 - 01:27 PM
Once it is all mounted up you will not see that much of a gap.
Posted 30 June 2022 - 03:34 PM
How's it compare in other spots?
The angle of the bottom ends of the side finishers wouldn't have to be far out & then the the curve of the grille itself. Fitting it up on the car may be the best way.
Posted 30 June 2022 - 08:40 PM
I've got it all fitted now but it is just all round bigger - both longer and higher!
Will take a before and after photo for interest
