Replacing Front Brake Pads Question
13 replies to this topic
#1 JDMRoverMini
JDMRoverMini
  • 96 posts
Posted 02 July 2022 - 05:41 PM
I"ll be replacing the front brake pads only. All other parts appear good, and not needing replacement at this time, but I have some squeak when braking.
I believe the process should be:
  1. remove split pins and and anti-rattle springs
  2. remove old pads
  3. clean calipers
  4. refit new pads with anti-rattle springs and split pins
do I need to bleed the brakes, or do anything with the reservoir? I can top of fluid, but what else?
#2 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 02 July 2022 - 05:49 PM
Yes those steps are correct but you'll need to push the pistons back, so it'll look like:
remove split pins and and anti-rattle springs.
remove old pads.
clean calipers push back pistons (I do this before removing the old pads, so using a large screwdriver to pry between the pad and disc).
A light smear of grease on the ears and back of the pad
refit new pads with anti-rattle springs and split pins (renew split pins)
Remember to pump the brake pedal until pressure point is back to where it was BEFORE DRIVING
Hope this helps and solves any issues you may have (anything you ain't sure about please reply on the thread, there is never a silly question!)
Cal844
#3 panky
panky
  • 1,792 posts
Posted 02 July 2022 - 06:00 PM
And make sure there's enough room in the reservoir for the fluid pushed back from the callipers.
#4 JDMRoverMini
JDMRoverMini
  • 96 posts
Posted 02 July 2022 - 06:37 PM
Since pushing back the piston moves fluid from the lines, increasing the reservoir level, correct?
But no traditional bleeding needs to be done?
Edited by JDMRoverMini, 02 July 2022 - 06:38 PM.
#5 JDMRoverMini
JDMRoverMini
  • 96 posts
Posted 02 July 2022 - 06:40 PM
Cal844
Car on or off?
#6 Alex_B
Alex_B
  • 4,573 posts
Posted 02 July 2022 - 07:06 PM
Cal844
Car on or off?
Doesn't matter, pumping the brake pedal just ensures the pistons in the calipers get pushed back out and means the pads are sitting in their correct position close to the disk.
No bleeding will be required provided air doesn't enter the system, but you would have to drain the reservoir or have a leak in the hydraulic lines to let air in.
#7 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 02 July 2022 - 07:18 PM
Cal844
Car on or off?
Either, If its a servo equipped mini I'd recommend to start the engine to let the servo help you
Edited by cal844, 02 July 2022 - 07:18 PM.
#8 JDMRoverMini
JDMRoverMini
  • 96 posts
Posted 02 July 2022 - 07:52 PM
Cal844
Car on or off?
How do I know if I have a servo. It's a 96 JDM SPi.
#9 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 02 July 2022 - 08:36 PM
A 1996 should have a servo. It’s the black round canister between the pedal box and master cylinder
Unless you know when the brake fluid was last changed, it might be a good idea to do a fluid change. It’s service life is normally rated at a few years
#10 panky
panky
  • 1,792 posts
Posted 02 July 2022 - 10:13 PM
Correct
#11 Midas Mk1
Midas Mk1
  • 5,787 posts
  • Local Club: S.U.N.M.C
Posted 03 July 2022 - 11:23 AM
Please get a haynes manual and read thoroughly, this isn’t a task you should be doing if you don’t fully understand the process.
Edited by Midas Mk1, 03 July 2022 - 11:24 AM.
#12 bpirie1000
bpirie1000
  • Area Managers
  • 2,373 posts
  • Local Club: Amoc
Posted 03 July 2022 - 12:56 PM
I would suggest whipping the drums off and make sure everything was dry and plenty meat on the shoes.
Do it now before anything needs done on the motorway....
#13 Ethel
  • 26,060 posts
Posted 03 July 2022 - 02:21 PM
There's nothing different about Mini discs if you know anyone with a bit of car experience to lend a hand.
I'd remove the pads one at a time and press the pedal to push the piston a bit farther out so you can inspect & clean it - but you have to be careful not to eject the piston completely! They're designed for that not to happen if the pad is worn down to the metal to give you an idea. Large spanners make good levers for pushing the pistons back in, repeat until they move with barely no resistance at the pedal.
It's not a bad idea to use it as an opportunity to draw fresh fluid in to the caliper, but be wary the bleed screws can seize if they haven't been touched in a while and will be a much bigger job if you shear one. Proceed with caution if you need the car roadworthy. (and keep an eye on the fluid reservoir for topping up, with the same specification of fluid - usually Dot4)
Also, while you've got the wheels off inject some grease in the suspension joints - you will need a grease gun if you're going to be a Mini's domestic servant.
#14 coopertaz
coopertaz
  • 806 posts
  • Local Club: a-series-magpies
Posted 04 July 2022 - 12:28 PM
also remember after renewing pads brakes may feel poor until pads are bedded in and drive steady first couple of days with this in mind.
