Has anyone heard of carbon cleaning with hydrogen? can this be done on the mini without harm?
Run On - Spark Plug Issue?
#16
Posted 13 July 2022 - 02:58 PM
#17
Posted 13 July 2022 - 06:30 PM
You mean water injection. It can be done but the mini doesn't have high enough fuel pressures so takes longer
#18
Posted 18 July 2022 - 02:17 PM
I believe is the modern take on water injection but theres a machine that is plugged injecting hydrogen in the air intake..
#19
Posted 24 July 2022 - 06:10 PM
After much fiddling, I did research on the timing figures of the RSP and Mainstream Cooper. (Cooper models with carb and catalytic converter) It was very hard to find the user manual, and I found one in french.
Timing should be 5degrees with vacuum advance disconnected @1000rpm.
set and done. no more run on. Hope it helps someone looking for the same information. Ill post the pdf here:
Posted 25 July 2022 - 03:46 PM
#21
Posted 25 July 2022 - 08:51 PM
The idle timing, total timing & the curve in the middle are all important for good performance
#22
Posted 26 July 2022 - 01:18 PM
Timing should be set according to many factors, cam, compression, fuel, etc
Totally agree,, I did to factory specs as the car is stock from factory. It fixed my issue, and I feel a power increase in how the car accelerates now. :) Thanks everyone for your help!
