Interchangeable Parts With Rod And Remote Boxes
8 replies to this topic
#1 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 14 July 2022 - 06:08 AM
Hi. I’ve taken apart a remote 998 4 synchro gearbox for someone at the club to see what’s serviceable. It needs a lot of parts as it’s seen some water damage. I’ve also got about 5 gearboxes worth of good, used rod change internals, bearings, etc. I’ve tried searching a few topics to no avail, just wondering how much of the rod change gearbox will work in the remote gearbox.
It looks like I can fit the rod change layshaft, layshaft bearings and the layshaft gears without issue and by eye and measurement, they’ll maybe work with the remote mainshaft, Any other parts??
#2 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 14 July 2022 - 06:22 AM
I did a similar thing a few years ago, I had 4 rod changes boxes and wanted a remote. The amount of compatible parts will depend on the age of the rod change boxes, the early ones will share more parts.
The laygear and the main gear cluster can all be used
Diff & side covers can be used (rod change have the additional flange to hold in the plunger/spring but you can trim this off or leave it)
The reverse gear is different
Obviously the gear change mechanism is all different
#3 fikus01
fikus01
  • 1,910 posts
Posted 14 July 2022 - 06:38 AM
Thanks Timmy. It did look like some things were the same.
#4 whistler
whistler
  • 1,818 posts
Posted 14 July 2022 - 08:18 AM
I've recently put a set of rod change clubman straight cuts into a remote box. The only mod I had to do was to be able to fit the 3 step layshaft. I had to sort of countersink the laygear side of the casing web for the 1st layshaft step to fit properly.
Engine/gearbox fully built but only run on my garage floor. I actually didn't fit the remote change but did the magic wand conversion on the back of the remote diff.
p.s. Thanks Spider, forgot about the reverse gear; needed to change that.
Edited by whistler, 14 July 2022 - 10:59 AM.
#5 Ethel
  • 26,073 posts
Posted 14 July 2022 - 10:47 AM
Fewer problems likely if you can keep the gears as complete sets.
#6 Spider
  • 15,136 posts
Posted 14 July 2022 - 10:50 AM
Depends a little of what vintage / type of Rod Shift Boxes you have, but even then, that's not insurmountable.
The Gearsets interchange, except for Reverse gear, in fact, the Rod Shift Boxes to 1978-ish had the same gear sets (except as noted, reverse).
From about 78 on, they went to a 3 step Layshaft, which the case has a counterbore for. There are 'short' 3 step layshafts about that let you fit these later Laygear in to the earlier cases, or going the other way, the early gear set will fit straight in to the later cases (except as noted, the remote Reverse gear).
The Selector Forks and Rods between the 2 types though are totally different.
The Diffs readily swap, however the side cover need to be the correct type to i) be used with the diff output coupling (Uni Joint, Pot Joint etc) and the correct one needs to be used on a rod shift, but any can be used on a remote type.
#7 fikus01
fikus01
  • 1,910 posts
Posted 25 October 2022 - 07:23 PM
Thanks everyone. Ive done this now. the case needed modifying to take the3 step layshaft as per some of your experiences. But otherwise it all went smoothly. Thanks for the help.
#8 whistler
whistler
  • 1,818 posts
Posted 26 October 2022 - 09:50 AM
Love it when a plan comes together.
#9 fikus01
fikus01
  • 1,910 posts
Posted 08 November 2022 - 02:47 PM
Ive put a video together covering it if anyone is interested
Classic Mini Gearbox - A+ Gearset in a Remote Gearbox Casing
https://youtu.be/4IYUK77d0mE
