Wiring Problem
6 replies to this topic
#1 dolli93
dolli93
  • 34 posts
Posted 14 July 2022 - 09:30 PM
Wiring is almost on finished on my 1991 rover mini 1275 but having some problem figuring out where some wires go. Here are some pictures of the wires
https://imgur.com/a/Ry5WAGP
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 15 July 2022 - 01:32 PM
That wire you are holding looks aftermarket, what wire colours and also where is it located? The relay in the background of the shot is also aftermarket
#3 Ethel
  • 26,580 posts
Posted 15 July 2022 - 02:49 PM
First photo: brown is permanent live, white is ignition live, black is earth. So is could be the relay is intended to turn something on when the ignition is on - where does the red wire go? Terminals 85 & 86 would be either white or black, 30 brown, 87 whatever is being switched on.
Second photo: Twin red/black is side lights, the missing wire to the sidelight may be solid red or another colour. The single bullet could be the indicator, if the colours are green/red??? No idea on the half a fuse holder.
Third photo:  O_O
#4 stuart bowes
stuart bowes
  • 2,530 posts
Posted 15 July 2022 - 04:09 PM
Third photo:  O_O
pmsl
#5 Aly-g
Aly-g
  • 460 posts
  • Local Club: Still looking
Posted 15 July 2022 - 11:26 PM
Could do with some Tessa tape and good connectors me thinks .
Allan
#6 MrE812
MrE812
  • 39 posts
  • Local Club: ELMOC
Posted 23 July 2022 - 06:37 PM
Woah,  that loom has had some "adjustments" made to it I think.
Those black wires would normally be earth/chassis ground wires.
Is that a glass fuse with wires wrapped / soldered onto it? pretty sure that's not factory.
Looks like a connector where the wire is missing too.
Since the wires seem to change colour too in some cases it makes things challenging to guess what they were for.
I'd be getting my multi-meter out and tracing some of these back.
Good luck.
#7 bpirie1000
bpirie1000
  • 2,539 posts
  • Local Club: Amoc
Posted 28 July 2022 - 09:50 AM
Try to label each wire or write it down somewhere.. save a few headaches later on in life.. or another mini owner....
