Brake Servo No Releasing
Best Answer cmonson , 01 August 2022 - 03:52 PM
Not enough free play in the brake rod.If the port in the master is not uncovered when the pedal returns it holds pressure in the system.Steve..
I think I have it fixed. I adjusted the rod that comes out of the back of the booster itself. Just loosened the nut and backed it off about 2 full turns and then re-tightened the nut.
The brake pedal still feels really good and the front calipers don't seem to be hanging up any more.
The only thing that I needed to move was the relay pack. Pretty simple adjustment to make.
Go to the full post
Posted 18 July 2022 - 10:26 PM
Posted 18 July 2022 - 10:37 PM
If you experienced this issue before what was the fix, as it may point you in the right direction to repair now ?.
Posted 18 July 2022 - 11:12 PM
It seemed to go away when I replaced the booster itself.
Posted 19 July 2022 - 05:57 AM
Posted 19 July 2022 - 12:02 PM
Have you had a look at the pistons?
It could be they are not retracting due to rust.Not a difficult job to rectify.
Good luck
Posted 21 July 2022 - 12:28 AM
I had a similar issue with a clutch, it turned out to be collapsed / collapsing internal hose, though the outside looked good.and in perfect condition.
I assume you have replaced all the hoses, but is one "twisted" even a little bit?
Posted 01 August 2022 - 03:52 PM Best Answer
