Accelerator Cable Radius
15 replies to this topic
#1 IronmanG
IronmanG
  • 1,253 posts
  • Local Club: Box hill. Lsmoc member
Posted 19 July 2022 - 05:40 PM
Whats the minimum radius the accelerator cable can bend it to not be compromised in its performance.
My pedal stuck to the floor last week, then the cable luckily popped off the pedal end and the engine immediately went to idle.
I think the tight radius maybe restricting the smoothness. I am going to make a few changes but the best I can do with the filterin place is about a 10mm improvement. The filter pretty well touches the fuel rail.
Any suggestions
Attached File  Screenshot_20220719-085214_Gallery.jpg   24.14K   13 downloads
#2 Shooter63
Shooter63
  • 1,079 posts
Posted 19 July 2022 - 05:47 PM
What make of throttle bodies are they, I know jenvey make a kit to convert the action to side pull, it bolts on the top of the body and pulls along the engine line.
Shooter
#3 nicklouse
  • 18,696 posts
Posted 19 July 2022 - 05:57 PM
That looks way too tight to me. I would have it as big as possible.
#4 IronmanG
IronmanG
  • 1,253 posts
Posted 19 July 2022 - 06:11 PM
Shooter
At power. I will look on the website
#5 nicklouse
  • 18,696 posts
Posted 19 July 2022 - 06:23 PM
Just a thought what return spring(s) have you fitted.
#6 IronmanG
IronmanG
  • 1,253 posts
Posted 19 July 2022 - 06:29 PM
That is currently as the air filter backplate is within about a mm of the fuel rail.
I can change to sock filters which I have reservations about in comparison to the itg I'm running currently and that would allow me to have whatever radius I want but then I have to plumb my breathers into something else
I have taken it off and it seems to run freely when I bend it by hand
#7 IronmanG
IronmanG
  • 1,253 posts
Posted 19 July 2022 - 06:43 PM
Hhmm I don't. Its quite heavily sprung anyway
You mean this 1.
#8 nicklouse
  • 18,696 posts
Posted 19 July 2022 - 06:46 PM
Well not that in particular. But it might be an idea to add one to the cable attachment so the cable is pulled back. Just be aware of wear.
#9 IronmanG
IronmanG
  • 1,253 posts
Posted 19 July 2022 - 07:02 PM
So the MPI has it on the pedal instead of engine side?
#10 imack
imack
  • 2,203 posts
Posted 19 July 2022 - 08:00 PM
Could you run the throttle cable round a pulley like this?
This is a mountain bike item (cog hog) from the 1990's to improve cable routing into the rear derailleur but would probably plug straight into the throttle cable ferrule if you can find one.
#11 IronmanG
IronmanG
  • 1,253 posts
Posted 19 July 2022 - 08:22 PM
O thats a good idea.
#12 IronmanG
IronmanG
  • 1,253 posts
Posted 19 July 2022 - 08:24 PM
I just had a look at the AT site and the cablemlinkage pull can be to 1 side of Central. If I can change it to the side it might avoid the filter enough but that able router is a great
ideaAttached File  Screenshot_20220719-211829_Gallery.jpg   37.39K   6 downloads
#13 IronmanG
IronmanG
  • 1,253 posts
Posted 19 July 2022 - 08:29 PM
And just found this
Motorbike 90 throttle cable
adjusterAttached File  Screenshot_20220719-212800_Gallery.jpg   15.14K   3 downloads
#14 Ethel
  • 26,073 posts
Posted 19 July 2022 - 10:32 PM
A pedal spring will just lift the weight of the pedal. It won't do much to feed the cable back to release the throttle(s).
The bends don't look too bad to me, but there looks to be a bit of a kink where it enters the ferrule on the bracket. Will it run underneath the manifold? I'd have thought that might be a bit more direct and shorter route.
Also, if the cable came loose at the pedal, do you have a retainer clip, NAM6923?
#15 IronmanG
IronmanG
  • 1,253 posts
Posted 20 July 2022 - 10:20 AM
No I dont
Edited by IronmanG, 20 July 2022 - 10:22 AM.
