Hi All,
Can anyone tell me what the difference is between a DAM2922 Primary Gear and a DAM8888 Primary Gear, which was the replacement part from I believe in 1979, and why was this change over done?
Regards Paddy
Posted 20 July 2022 - 04:47 PM
Hi All,
Regards Paddy
Posted 21 July 2022 - 03:44 AM
I've not heard or seen a DAM2922 nor can I find a reference to one, not to say they don't exist.
There was a few before this gear, but they were 24 tooth types, the 22A1493 being the 24 tooth type before they went to the (so called) A+ Drop Gears and the DAM8888, which has finer teeth and 29 of them. The 22A1493 went in to production about 1963-ish and carried through to mid - late in 1979.
Posted 21 July 2022 - 05:19 AM
Hi Spider
The Dam2922 has 29 cross cut teeth and from the research I have done the DAM8888 replaced it i but cannot find out why this was done.
Edited by Designer, 21 July 2022 - 05:24 AM.
Posted 21 July 2022 - 06:30 AM
I agree with Designers comments above. I can find reference to it, and the fact it was repalced around 1979 but no idea why or indeed what the difference between the two were.
Posted 21 July 2022 - 10:48 AM
I dug down and found the DAM2922. I know I have one of these in an old engine. Off hand, I can't recall any material difference between that and the later type.
Actually,,, thinking more about it, I have a few NOS DAM2922's.
When I get back home in about a week, I'll have a look.
Posted 21 July 2022 - 11:11 AM
Hopefully the front and rear bushes are both of the correct material in DAM2922 and not this Silicone Bronze rubbish.
Posted 21 July 2022 - 11:52 AM
The bushes were the same.
The factory never used Silicon Bronze.
