Oil Pressure Illumination
6 replies to this topic
#1 YoungCally9
YoungCally9
    Starting My Mini Up
  • 1 posts
Posted 22 July 2022 - 10:59 PM
Hi All,
Looking to get some clarification on the operation of the oil pressure lamp on my '88 Austin Mayfair (3 Clock Dash). When I turn the ignition on, should the oil pressure lamp illuminated then distinguish or should it remain off at all times unless there's a problem. The reason I ask is that the red light (battery charging) will illuminate then distinguish when the ignition is turned giving me confidence that the bulb is okay. As for the orange oil pressure bulb, I've never seen this light up at all - should I take this is a good sign.
I should say, I don't have any concerns that my mini is suffering from low oil pressure, I'd just rather know before it's too late!
I plan to install an oil pressure gauge in the winter when the car is hibernating however would like to have both the guage and light in operation just for added security.
Thanks in advance.
Dylan McAllister
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 23 July 2022 - 08:17 AM
It should act like the battery light, so on with ignition then once pressure builds it goes off.
#3 nicklouse
  • 18,998 posts
Posted 23 July 2022 - 10:03 AM
Sounds like the bulb has blow or the wire is not connected.
#4 Chris1275gt
Chris1275gt
  • 1,029 posts
Posted 23 July 2022 - 11:23 AM
Mine with the same problem was a faulty switch, with engine off pull the wire off the switch and check the continuity between the switch spade and the block.
Edited by Chris1275gt, 23 July 2022 - 11:26 AM.
#5 roblightbody
roblightbody
  • 459 posts
Posted 23 July 2022 - 02:23 PM
A copy of the original handbook is still useful for basic questions like this!
#6 Spider
  • 15,684 posts
Posted 23 July 2022 - 07:51 PM
Your summation of OK / Not OK is and basic operation is correct.
A simple test here is to pull the wire from the Switch on the Engine, short it to Earth, turn the Key ON and the Lamp should come on.
If it doesn't, then there's a wiring or Bulb issue.  If it does, then there's a Oil Pressure Switch issue.
#7 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 24 July 2022 - 02:50 AM
My oil pressure light came on and then off when starting up, but started to flicker especially when I hit the throttle after braking. First thought was oil pump, but it was newly replaced. So, after a quick check, there was apparently a break in the wiring.
