Speedo Drive Pinion And Spindle - Interchangeability?
3 replies to this topic
#1 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 27 July 2022 - 12:51 PM
Hi everyone,
I am reconditioning a gearbox - should be from an SPI - and switching from 3,1 diff to 3,44.
Currently the box has a 7/17 pinion and spindle drive for the speedo.
I want to build the box later in my car which has a 140kph smith center speedo (tpk 800) and will be on 145/10 wheels. Maybe later on 165/70/10 but this does not make a  difference.
According to Guessworks website I need a 6/17 worm and pinion ratio.
Can I use the 17 I already have and buy a 6 teeth worm? Do the gears match together? Or do I need to buy a complete 6/17 matching drive?
the 7/17 combination would be far off the real speed...
Gilles
#2 nicklouse
  • 18,652 posts
Posted 27 July 2022 - 05:34 PM
There is a loverly how to and what to use with what and how to identify things on the Guessworks website.
#3 Spider
  • 15,010 posts
Posted 27 July 2022 - 05:39 PM
I have in the past with no issues.
#4 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 02 August 2022 - 11:53 AM
Thanks for the answers.
I just saw while surfing on Minispares (that may be expensive...) this chart below the page which explains everything.
The pinion 22A1881 has been used pretty often paired with 6 and 7 spindles, for diff ratios 2,95; 3,1; 3,44 and 3,76.
And Minispares says although it's for some pinion/spindle ratios not the best, they would work. This confirms Spider's sayings :)
So a 6 teeth spindle it will be.
Gilles
