Runs With Key Off
2 replies to this topic
#1 Sam Burnette
Sam Burnette
    Starting My Mini Up
  • 2 posts
Posted 04 August 2022 - 10:15 PM
I am new to Minis, I have a 1993 Spi Mini. Sometimes the engine will keep running when I turn the key off, Not talking about run on, it will continue to run until you disconnect the coil. With the switch off, I do get the alternator light, if I go back to the run position the light goes off. I can even pull the key out and it continues to run. It has happened a couple of times, seems like something is going bad. Could this be a bad ignition switch? Any help would be appreciated.
#2 Aly-g
Aly-g
  • 460 posts
  • Local Club: Still looking
Posted 04 August 2022 - 11:24 PM
is this a problem that has just started ? have you been doing any electrical jobs on your car ? if the answer is no then I would say it is the ignition switch.
Allan
#3 Sam Burnette
Sam Burnette
    Starting My Mini Up
  • 2 posts
Posted 12 September 2022 - 12:39 AM
Did you get the problem resolved. I am having the same problem. Thanks
