Painting Inside Front Wheel Arches
5 replies to this topic
#1 pete l
pete l
  • 1,415 posts
Posted 06 August 2022 - 03:50 PM
Hi all.
How do you people paint the inside of your front wheel arches?
My paint gun won't fit and I can't see an easy way of getting around this.
All ideas welcome 😁
Pete.
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 06 August 2022 - 04:03 PM
Depends on the finish you are after
If you want textured stone guard then the easiest way is it use a tiltable stoneguard which you can add your body colour to and then apply it with a schutz gun
If you want smooth shiny topcoat finish then you can do it with the spray gun but wil need to reduce the fan size right down and up the pressure and spray it through the headlamp hole as well as from under the arch but you need patience as it's not easy.
Other option might be a mini spray gun which would give you better access but you will still be working blind
Edited by Ben_O, 06 August 2022 - 04:03 PM.
#3 stuart bowes
stuart bowes
  • 2,287 posts
Posted 06 August 2022 - 08:01 PM
I was just going to paint underseal under there with a paint brush.. is that not normal
A slightly more utilitarian approach perhaps
Edited by stuart bowes, 06 August 2022 - 08:03 PM.
#4 Cooperman
  • 23,362 posts
Posted 06 August 2022 - 10:16 PM
I normally use a bitumen based paint of the sort used to protect the hulls of narrow boats. It's fantastic stuff which I get from my friend who owns a marina in our village.
It is applied with a normal paint brush.
#5 pete l
pete l
  • 1,415 posts
Posted 07 August 2022 - 07:34 AM
I'm actually talking about epoxy primer, I have new wings and A panels and I've rubbed down the inner wings.
I tried doing what Ben said but the finish is dry and rough. Should I thin the primer down a bit with 2k thinners? .
#6 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 07 August 2022 - 09:51 AM
All depends on the needle size in your gun
smaller needles require the paint to be reduced more or you will get a dry finish.
