hello all
I'm going to be removing the complete floor skin (Leaving in the cross beam) on my mk1 mini. I just wanted to know if there's any tips or pitfalls to watch out for?
thanks Mike
Posted 07 August 2022 - 05:25 PM
hello all
thanks Mike
Posted 07 August 2022 - 06:03 PM
hello all
thanks Mike
It won't be much fun driving through puddles.
Posted 07 August 2022 - 06:09 PM
Posted 08 August 2022 - 10:39 AM
make sure you brace up shell enough. did gf's and braced between both a posts and b posts and also across car between both a and both b posts then diagonally, with 20mm bar, probably overkill but didnt flex! before cutting anything. remove crossmember as is attached to inner sills which are floor pan. if i did it again would get full floor including outer sills from m-machine. remember heel boards are different on later cars
Posted 08 August 2022 - 02:17 PM
Thanks for the info.
Ive put a new boot floor in already, so its just the floor in the cab, but i'll brace it now you've said that.
thanks Mike
Posted 08 August 2022 - 02:53 PM
Posted 12 August 2022 - 02:16 PM
Hi The heal board isn't too bad, so thats staying, just needs a couple of repairs on the lip.
Posted 13 August 2022 - 08:03 AM
You won't want it to lozenge, so fix the diagonals where that'd matter - between the front & rear subframes & the door apertures. Have as much fitted as you can & test fit what you can't before you fully weld it up.
