Aftermarket Ecu For Mpi Fuel System
6 replies to this topic
#1 nont_za
nont_za
    Starting My Mini Up
  • 3 posts
Posted 15 August 2022 - 10:20 AM
Hi all, I would like to change the Rover MEMS 2J MKC104292 to aftermarket ecu which still use its own siamese inlet. I about to go for 1,380cc multiweb with 270-280 cam. Rover oem ecu may not cope this kind of level. Many go for specialist components but that comes with new throttle body. I have to stay with siamese inlet since the mpi enigne is really rare here in my country. I am not sure what options between 1.sending my rover oem ecu to let someone install the chip/rom to make it mappable or 2. change to aftermarket like haltech, emerald, etc
#2 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 15 August 2022 - 12:22 PM
The Polestar ecu can be used, but I'm yet to see one on an MPi make any decent result. The standard ecu is being opened up and there are a few people that can now map it.
#3 sonscar
sonscar
  • 3,047 posts
Posted 15 August 2022 - 01:02 PM
You must have one that can run sequential with only two large injectors.It has been a long time since I researched ECU but I suspect that very few can do this.You do not want to be worse off,Steve..
#4 Steve220
Steve220
  • 5,067 posts
  • Local Club: BMC
Posted 15 August 2022 - 05:01 PM
There's more to it than just running sequential. The MPi has a VERY unique injector firing sequence.
#5 sonscar
sonscar
  • 3,047 posts
Posted 15 August 2022 - 05:31 PM
Indeed,I faced the same problem twenty years ago with my MGB.The complexities were so great that I ignored them and blindly went ahead.Still working,Steve..
#6 jamesmpi
jamesmpi
  • 1,940 posts
Posted 21 August 2022 - 02:36 PM
Do you have any more info on this?
I haven’t been on this forum for ages and have a 1380 Mpi but running standard ECU. I wasn’t aware that the standard ECU had been “cracked” 😆 I was always under the impression is was uncrackable lol or wasn’t worth the effort
#7 tmsmini
tmsmini
  • 734 posts
  • Local Club: MOASF
Posted 21 August 2022 - 02:44 PM
Some info is here:
https://rovermems.com/remapping/
Actually more info here for MEMS2J
https://rovermems.co...s-2j/index.html
Edited by tmsmini, 21 August 2022 - 02:52 PM.
