How To Protect The Bodywork After Welding?
Posted 17 August 2022 - 10:49 PM
I'm just about to start welding in some patch panels, would epoxy primer be enough to protect the new welds from rusting as it might be a while until it gets a full spray? The car will be outside under a cover.
If not what should I do?
Thank you.
Posted 17 August 2022 - 11:40 PM
My mini is in a garage though so is protected to a degree anyway.
Posted 18 August 2022 - 09:26 AM
Wire wheel the area then pump zinc rich primer through it.
Posted 18 August 2022 - 12:24 PM
painted mine with zinc rich primer and cavity waxed interior, been 2 years now (i'm a lazy git) and still ok. although in garage
Posted 18 August 2022 - 01:32 PM
Once all of the welding is done and with the car being outside I would waxoyl or Bilt Hamber the internal areas. All external I use epoxy primer.
Posted 18 August 2022 - 03:32 PM
Epoxy will be fine.....both sides if possible, after thoroughly dressing the welds as that's where rust often starts
Posted 19 August 2022 - 12:22 AM
Thanks for the advice all.
