Hi everyone,
new to minis and new here so please bear with me.
I acquired a 1996 mini sprite, believe its an SPI, its ran rich since the first day I've had it, lots of black soot and extremely rich smell. It underperformed for quite some time, spluttered when you put your foot down in 3rd and 4th and would often stall randomly when slowing down and changing down into first. Think the previous owner has mucked around with vacuum lines, they look homemade and don't look like they all go to the right places. For example there was no vacuum line from the ECU to the fuel trap? I have bought and fitted one which has fixed some of my issues but believe it's still running rich.
I discovered a couple of weeks ago that it had an immobilizer, when I clicked the key fob by accident and it wouldn't start. I was chuffed that it actually worked as apart from that there isn't much to secure the little car. Its been working fine for the past weeks, been driving it every day and having no issues. When immobilized if you open the boot an alarm goes off, guess this should be the same for the doors but guessing the sensors have stopped working?
Anyway, I took it out in an evening this week, and for some reason it just lost all power completely, can't remember going over a bump or anything. It didn't exactly cut out instantly, just started to die and throttle was going nothing. Pulled over in the middle of nowhere and began trying things to get it to start. ALL ELECTRICS WERE WORKING, but it WOULDNT CRANK, which is confusing. No crank would be suggesting starter motor issue but why would that have caused it to die? I tried the fuel cut off switch but again this wasn't really going to do anything as fuel isn't really an issue if the engine wont turn over. Immobilizer was still clicking and red light coming on and off but this made no difference, I did notice however, whenever I tried to start the car, the red light would come on and start flashing, it would go away if I immobilized it and de immobilized it again, not sure if this is anything to do with the issue.
Eventually had to get towed home, whilst doing so, I thought I would try a bump start out of curiosity. The engine fired up but the instant I would clutch or touch the throttle it would die out again.
Sorry its so long winded, would really appreciate any help anyone has on this, don't have a clue where to go from here, used to completely mechanical old land rovers where electrics aren't really and issue so bit clueless lol.
Keith
