Rover Mini 1995 Immobiliser Fault.
11 replies to this topic
#1 patbern
patbern
    Just On Tickover
  • Validating
  • 5 posts
Posted 29 August 2022 - 12:15 PM
Hi
I'm new the forum.  This is my first venture with a newer mini with an ECU & immobiliser.  I have a problem with the immobiliser as the car is turning over but there is no LED illuminated on the dash for the immobiliser.  Has anyone experienced this issue?  I would appreciate any input to trying to solve this.
Thanks in advance
Pat
#2 MatthewsDad
MatthewsDad
  • 824 posts
Posted 29 August 2022 - 02:16 PM
Just checking, is the problem that it's not firing up, even though there's no red light showing on the dash?
#3 patbern
patbern
    Just On Tickover
  • Validating
  • 5 posts
Posted 29 August 2022 - 04:02 PM
Hi thanks for replying.Yes no red light at all and no noise from the fuel pump.
#4 patbern
patbern
    Just On Tickover
  • Validating
  • 5 posts
Posted 29 August 2022 - 06:19 PM
Hi yes wont start but it is turning over.The immobiliser light dose not come on at all.
#5 patbern
patbern
    Just On Tickover
  • Validating
  • 5 posts
#6 Quinlan minor
Quinlan minor
  • 1,211 posts
  • Local Club: LSMOC
Posted 29 August 2022 - 06:30 PM
Try fitting a new battery in the remote.
Hit the arm button repeatedly, leave for a minute, then press disarm and then try starting the engine.
#7 patbern
patbern
    Just On Tickover
  • Validating
  • 5 posts
Posted 29 August 2022 - 06:46 PM
Thanks will try that.
#8 viz139
viz139
  • 688 posts
  • Local Club: Irish Mini Owners Club
Posted 30 August 2022 - 10:43 PM
If the immobilizer is on , the red led is on, the engine will not turn over , the fuel pump will not prime
If the immobilizer is off , the red led is off, the engine will  turn over , the fuel pump will  prime
As your engine is turning over it would suggest the immobilizer is off and so the led should be off.
possable causes of the pump not running are inertia switch tripped, fuse blown or faulty relay.
#9 Quinlan minor
Quinlan minor
  • 1,211 posts
  • Local Club: LSMOC
Posted 31 August 2022 - 12:03 AM
Mine turns over with the immobiliser on but will not start.
I suggested the above in case the red light is not working.
#10 MatthewsDad
MatthewsDad
  • 824 posts
Posted 01 September 2022 - 06:33 AM
Hi pat any success? I checked mine and it can turn over with the immobiliser on.
#11 MatthewsDad
MatthewsDad
  • 824 posts
Posted 01 September 2022 - 06:35 AM
#12 MatthewsDad
MatthewsDad
  • 824 posts
