A Panel Flange
3 replies to this topic
#1 Gaz66
Gaz66
  • 913 posts
Posted 30 August 2022 - 06:08 PM
Does the flange on the hinge pillar taper off at the bottom like it does at the top?
Im having to rebuild both flanges and dont know if they are straight or flared out like the top.
#2 stuart bowes
stuart bowes
  • 2,121 posts
Posted 30 August 2022 - 06:16 PM
this should get you close, traced from a heritage panel
horizontal marks are 10mm intervals, numbers are distance from straight edge
it's not absolutely perfect obviously you might want to add a mm to each and allow yourself the option of filing down later
this would be the off side, i.e front of the car to the right
Edited by stuart bowes, 30 August 2022 - 06:38 PM.
#3 stuart bowes
stuart bowes
  • 2,121 posts
Posted 30 August 2022 - 06:40 PM
just to clarify that straight line is arbitrary just as a reference point, it is not the distance to the A post
this is just so you can plot out the full curve, use that to attach at the top, line up with what you've got and that will show you where the bottom should be
hope that makes sense
Edited by stuart bowes, 30 August 2022 - 06:44 PM.
#4 Gaz66
Gaz66
  • 913 posts
Posted 30 August 2022 - 07:37 PM
Excellent bit of info that Stuart.
Gaz
