Removing Door Mirror Glass
7 replies to this topic
#1 Flat-out
Flat-out
  • 18 posts
Posted 01 September 2022 - 06:10 PM
Hi, just wondered if anyone would kindly help explain how I remove the glass on the later plastic door mirrors? I can see there's a black frame. so is it just a case of levering this apart from the main body of the mirror? Many thanks.
#2 MikeRotherham
MikeRotherham
  • 990 posts
Posted 02 September 2022 - 09:37 AM
I've always thought the black bezel was glued to the body so not meant to be removed.
Has the glass broken?
#3 Flat-out
Flat-out
  • 18 posts
Posted 02 September 2022 - 06:05 PM
Hi Mike, thanks for your reply. The glass is badly scratched, probably best to buy another one then. Cheers mate.
#4 GraemeC
GraemeC
  • 7,446 posts
Posted 02 September 2022 - 06:53 PM
Replacements are available from MiniSpares. They look to have the bezel included so maybe the old one doesn’t come out unscathed.
I usually find having the new piece in your hand helps work out what needs to be done to disassemble
#5 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 04 September 2022 - 06:30 AM
The Minispares replacement plastic mirrors are glued to the back of the mirror housing. Mine somehow has detached itself (the quality of the glue, and the mirror as a whole, is not really good as originals). The glass themselves just sits there with minimal glue/double-sided tape to hold it. With care and perhaps a bit of heat, you can take them off, replace it with new glass, and re-glued them back in place.
#6 Red Riley
Red Riley
  • 161 posts
  • Local Club: British Car Club of Charleston
Posted 04 September 2022 - 02:22 PM
If you're going to replace the glass, just break it and take it out in pieces. You'll be able to see how it was held in once you've got the old glass out of the way.
#7 GraemeC
GraemeC
  • 7,446 posts
Posted 04 September 2022 - 04:29 PM
Is it a colour coded casing and if so what colour? I’ve a few NOS mirrors in random colours/sides.
#8 Flat-out
Flat-out
  • 18 posts
Posted 05 September 2022 - 06:48 PM
Thanks for the replies, much appreciated :-) Yes it's the colour coded in gloss black.
