Wiper Toggle Switch Upside Down
7 replies to this topic
#1 PikesTNT
PikesTNT
    Starting My Mini Up
  • 1 posts
Posted 08 September 2022 - 02:02 PM
I suspect I know the answer to this but….
I’m moving the wipers from the steering column to a centre switch panel to make the car look earlier. (Me and everyone else, apparently 😀)
All rewired and working fine but when I tried to mount the toggle switch in the centre panel, the D shape cut out is on the wrong side for the switch I have. If I mount it as is, UP will fast wipers and DOWN will be Off but that’s a bit mad
Have I bought the wrong switch? I know the correct Lucas one is meant to be 31780 but can’t see markings on mine. Did they really make left and right handed wiper switches for BMC cars and I’ve bought the wrong one?
As I say, I expect I have and it’s a hoary old elephant trap that many have fallen into before.
Thanks in anticipation
Pike
#2 Ethel
  • 26,580 posts
Posted 08 September 2022 - 03:23 PM
No Mini had 2 speed wipers through a rocker switch, it wouldn't have mattered on a single position switch. You could reposition all the crimped terminals in the connector bloke, but it might be easier to just take the switch apart & turn the rocker round.
#3 stuart bowes
stuart bowes
  • 2,530 posts
Posted 08 September 2022 - 04:40 PM
possibly a stupid question why can't you just swap the wiring around
(unless switch disassembly really is an easy job I suppose)
Edited by stuart bowes, 08 September 2022 - 04:41 PM.
#4 mini-mad-mark
mini-mad-mark
  • 921 posts
  • Local Club: northants wot no brakes
Posted 08 September 2022 - 10:34 PM
IIRC the toggle switches have a flat on both sides?  The switch would fit either way if the panel has a D shaped hole?
Failing that file the hole to a round hole so the switch fits the other way up?
#5 Ethel
  • 26,580 posts
Posted 09 September 2022 - 05:01 PM
Yes you can move the wires around
I'm wondering if we're slightly at crossed purposes. I'd assumed you were using Delta rocker switches, the same as on later Minis with wiper stalks. If you're using a rocker switch, with loose 1/4" spades, move the wires. There are plenty of Lucas wiper wiring diagrams online: they show the switch is never  "off", rather supplied via the park switch.
#6 Tds76
Tds76
  • 87 posts
Posted 09 September 2022 - 09:12 PM
Some Australian built minis had two speed wipers on the toggle switch.
Switches shown here
https://www.ausmini....hp?f=2&t=100414
I only have the single speed on mine and both the wiper switch and headlight switch were incorrectly fitted as down for off, so I flipped the switch panel round to fix it.
Cheers, Paul.
#7 Indigo
Indigo
  • 52 posts
Posted 11 September 2022 - 10:37 AM
I had the same problem on my 68 Mini when I converted the wipers to two speed.
The switch used was the one used on MG's.
I filed the flat out of the hole and turned the sitch up the other way.
Works a treat.
#8 whistler
whistler
  • 1,870 posts
Posted 11 September 2022 - 01:22 PM
You have the wrong switch. Just had the same on my 66. Found a correct one in my spares box with the flat (only 1) on the correct side.
