Dam 5626 Diff Housing Stud Dimensions
5 replies to this topic
#1 ac427
ac427
  • 733 posts
Posted 11 September 2022 - 07:19 PM
I've been looking on MiniSpares and Somerfield's to find the correct number, size and length of diff studs to replace the bolts the gearbox came with.
Is the following correct:
2x 22G1834 STUD-DIFF HOUSING TO GEARBOX CASING-LONG
3x CHS522 STUD 5/16" UNF/UNC x 2-3/4" ROCKER POST SHORT/DIFF HOUSING SHORT
2x CHS2620 STUD 3/8 UNF/UNC x 2 1/2"
Edited by ac427, 11 September 2022 - 07:19 PM.
#2 Spider
  • 15,684 posts
Posted 11 September 2022 - 07:50 PM
2 x 53K256
2 x 22G1834
3 x 53K1471
#3 ac427
ac427
  • 733 posts
Posted 11 September 2022 - 09:39 PM
2 x 53K256
2 x 22G1834
3 x 53K1471
Thanks Spider, Is 53K256 a special part.
[Edit] Should it be 53K266?
Edited by ac427, 11 September 2022 - 09:49 PM.
#4 Spider
  • 15,684 posts
Posted 12 September 2022 - 07:32 AM
2 x 53K256
2 x 22G1834
3 x 53K1471
Those numbers came from a Leyland Parts Book, None should be a special part !
#5 ac427
ac427
  • 733 posts
Posted 12 September 2022 - 04:28 PM
2 x 53K256
2 x 22G1834
3 x 53K1471
Thanks Spider, Which material do you think they are made from EN8 ?
#6 Spider
  • 15,684 posts
Posted 12 September 2022 - 06:12 PM
To be honest, I've never looked.
If I was to make some, I'd likely start from a Grade 5 UNF Bolt of the right length, cut the head off and cut the UNC thread.
Have you tried Somerfords ? That's where I bought quite a few a while back.
