I,m thinking of fitting Mk 2 rear lights to my 1990,s mini, does anyone have any advice on this, I realize that a new reversing light must be rewired and fitted, Basically I was wondering if the stud holes lined up and there are no visible gaps once fitted.
Mark 2 Tail Lights Conversion.
austin g
, Sep 12 2022 08:36 AM
3 replies to this topic
Posted 12 September 2022 - 08:36 AM
Posted 12 September 2022 - 08:38 AM
The later are bigger so you may seen lines where the old seals sat. Otherwise straight fit.
Posted 12 September 2022 - 10:09 AM
Straight swap but you may see where the paint has faded compared to the area covered by the seal.
Posted 12 September 2022 - 02:35 PM
From memory the plastic wiring connectors are different types so a bit more than 'plug and play' on the wiring side of things.
