Valve Stem Height
3 replies to this topic
#1 super6al
super6al
  • 80 posts
Posted 12 September 2022 - 07:09 PM
Hi
1990 carb cooper 1275 engine rebuild.
Had the inlet valve seats increased to 35.6mm about 18mths ago (exhaust seats are original).  Today I checked the valve installed height. I measured the valve tip to the machined face on the head & found the inlet valve tips are all higher than the exhaust, worst case by 22 thou (highest inlet is 1.224 " & lowest exhaust is 1.202"). No surprise I suppose since inlets were recut. Its not due to valve length as the exhausts are actually 10 thou longer than the inlets.
I can't find what the valve tip height should be - most posts are about valve spring heights - but I assume they should be all the same & then the rocker geometry can be set to suit.
Is this a big problem? If yes can I get the valve tips machined to correct the valve height. I don't particularly want to recut the exhaust seats if possible.
Alan
#2 Lplus
Lplus
  • 990 posts
Posted 12 September 2022 - 07:48 PM
Hi
Alan
Personally I wouldn't worry in the slightest.
#3 stuart bowes
stuart bowes
  • 2,530 posts
Posted 13 September 2022 - 11:12 AM
surely this is the reason why the rocker arms are adjustable
#4 Lplus
Lplus
  • 990 posts
Posted 13 September 2022 - 12:58 PM
Indeed, though I suspect the OP is concerned about a change in the rocker system geometry.
