Vmaxscart Efi Super Charger Adding Water/methanol Injection Snow Performance Stage 3
No replies to this topic
#1 cmonson
cmonson
  • 22 posts
  • Local Club: MOASF
Posted 12 September 2022 - 11:13 PM
Hello,
I currently have a Vmaxscart supercharger with EFI.
I am considering adding a Snow Performance Stage 3 water/methanol injection system to help cool down my intake temps.
I am picking this kit because it can take a reading off of the more accurate injector duty cycle vs a boost signal.
Probably a 50/50 mix of water/methanol.
Anyone currently running this setup?
If so, what size of injector(s) are you using?
My throttle body looks like a DCOE 40MM weber carb.  The current plan is to get 1" aluminum spacers between the throttle body and the super charger.  Drill and tap the spacers to accept the injectors.  Put 1 injector on either side of the throttle body.
