Drum To Disc Brakes
5 replies to this topic
#1 theoldmini
theoldmini
  • 159 posts
Posted 14 September 2022 - 05:15 PM
Having fitted 7.5 inch discs to a drum braked mini the front track is now wider than the rear.  What size spacers do I need to bring things into line.  I have fitted spaced drums to the rear but still not wide enough.  I realise I will have to change studs.  Many thanks
#2 Spider
  • 15,684 posts
Posted 14 September 2022 - 06:25 PM
The front track on a Mini and in fact most cars, is wider then the rear track.
Fitting the spacered drums as you have is also how the cars were produced at the factory.
#3 theoldmini
theoldmini
  • 159 posts
Posted 14 September 2022 - 06:34 PM
Thank you but does not look right.  The fronts sit with the wheels just protruding a little under the arches yet the rears are set inside.  Can I fit spacers with spaced drums.
#4 nicklouse
  • 18,998 posts
Posted 14 September 2022 - 06:47 PM
Don’t. The drums for the rear disc set up have a built in 1” spacer. That is all you need. There are other drums that have a much smaller spacer though.
#5 Hunter2
Hunter2
  • 211 posts
  • Local Club: Vancouver Mini Club
Posted 14 September 2022 - 07:06 PM
Wise to fit disc brakes up front...Minis are up against ABS equipped vehicles some with auto avoidance capability.  First bit of advice I give to new owners of drum braked classic Minis.
Though to be fair, we have an 86 year old owner of a MK I Countryman with single leading shoe drum brakes in the club and he manages to stop OK.  An experienced driver, he wisely leaves braking distance between himself and a leading vehicle.
As for rear drums the Cooper S drum will square up your track.
From observation, most 5" x 10" and 5" x 12" aftermarket wheels, will see tyres outside the body work.
I liked Minilite alloys in 5" x 10" but like the Cooper S offset alloys that keep the rubber within the body work.
#6 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 14 September 2022 - 09:24 PM
I have Cooper S disc brakes and Cooper S offset 4.5/10 Steel wheels (Repro) on my Estate, and they sit in at the back, my car does have 1 and 1/4 inch spacers for the rear wheels and is very tight behind the wheel to wheel arch, so much so that I can't fit a 165 tyre to the rims.
I suspect my car may have been in an accident in the past....
