Hardy Spicer Flanges
6 replies to this topic
#1 DeadSquare
DeadSquare
  • 3,101 posts
Posted 16 September 2022 - 06:30 PM
Are the Automatic and Manual Hardy Spicer diff flanges, interchangeable ?
#2 nicklouse
  • 18,585 posts
Posted 16 September 2022 - 06:43 PM
Yes and no. But generally if you have a set up the other part will fit. One used nuts the other bolts.
#3 imack
imack
  • 2,110 posts
Posted 16 September 2022 - 06:49 PM
I believe there are two types of factory hardy spicer flanges for the auto.
Early type are as shown in the Haynes manual, bolt on with collets, exactly the same as the Cooper S.
Late autos (pre pot joint) use knock on type hardy spicer flanges - they fit to a non Cooper S output shaft with a circlip exactly the same as a pot joint. They still use the larger diameter Cooper S/automatic side plates and bushes.
With the hardy spicer joint bolted up its impossible to tell if they're bolt on or knock on type.
2nd picture is bolt on type, all other pictures are knock on 'pot joint style'.
All use studs and nuts
Edited by imack, 16 September 2022 - 07:08 PM.
#4 Spider
  • 14,856 posts
Posted 16 September 2022 - 06:51 PM
Yes, only the side covers are not interchangeable, but the shafts and flanges etc are all the same. Also fitted to the 1969 - 1975 Mokes.
Hmm,,,, all the Auto's I've seen used studs and nuts, same a S. All out Autos were fully imported from the UK so would have been the same as whet you guys had. There was for a very short time though a 'conversion' the factory fitted that had Flanges on Pot Joint style Shafts, maybe they used bolts ? These were only in production a few months I believe.
#5 DeadSquare
DeadSquare
  • 3,101 posts
Posted 16 September 2022 - 07:30 PM
Thanks chaps.
I knew in the back of my mind that something on some boxes was different somewhere, ( yes, it is bolt / circlip ).
Just hoped that it wasn't different output diff pinion splines.
#6 imack
imack
  • 2,110 posts
Posted 16 September 2022 - 07:50 PM
Thanks chaps.
The output splines/output shaft diameters are different between the bolt on and knock on HS flanges.
Bolt on is larger diameter.
#7 DeadSquare
DeadSquare
  • 3,101 posts
Posted 16 September 2022 - 07:57 PM
Thanks chaps.
Oh ......  very rude word.
