Automatic Issues!
2 replies to this topic
#1 MyMinisNameIsBlanche
    Just On Tickover
  • 5 posts
Posted 01 October 2022 - 05:12 PM
Hi, my Automatic Mini is going in the garage for some work done and I need to know what my expectations should be…
* Do your autos idle as smooth in gear as in neutral?
* Is your shift between neutral and First/Drive a noticable movement of the whole car?
* Do your auto minis ever stall?
Thanks 🙂
#2 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 01 October 2022 - 06:20 PM
I've limited experience, but have owned an automatic 998cc mini in the past. My idle was the same in N, as when it was in Drive. I would usually get a little jerk forwards when moving from N into drive/first.
The stalling you mention in this thread (and I noticed your last thread too regarding stalling at the lights) I am unsure of. Does it happen when you leave the car in fully automatic mode, as well as if you come to a stop coming through the gears 'manually'?
Have you checked/changed the oil recently? Automatics are quite sensitive to oil changes, grades, and filling amounts (specifically the torque converter inside)
Edited by Retro_10s, 01 October 2022 - 06:20 PM.
#3 mab01uk
mab01uk
  • 12,538 posts
Posted 01 October 2022 - 06:51 PM
You might also find the Automatic Mini Register in link below useful:-
https://autominiregi....proboards.com/
