Rear Quarter Windows - Need Guidance
Posted 03 October 2022 - 09:47 PM
Posted 04 October 2022 - 09:37 AM
They shouldn't need a sealant, just the rubber, the frame should compress it on to the edge of the glass.
Posted 04 October 2022 - 09:42 AM
I would either use an old bike innertube as a gasket between the frame and the glass, or if that proves too tight/thick then sikaflex or tigerseal pu sealer (I think this is what you're asking)
Posted 04 October 2022 - 10:43 AM
I wouldn't go for something like Sikaflex in case you ever have to get them off again, probably plain old "B&Q" silicone would be better. I hadn't looked to see if new seals are available, but I'd guess you can find something suitable, for greenhouses maybe.
Posted 04 October 2022 - 07:35 PM
Will be getting the door wind up window seals soon, as the others available are too thick.
Ben
Ps: it's only 1mm thick rubber like inner tubes tho.
Edited by MacGyver, 04 October 2022 - 07:36 PM.
Posted 04 October 2022 - 07:41 PM
I've got to do the same job over winter as my glass is rattling in the frame as the rubber has perished. Minispares sell this http://www.minispare...86.aspx|Back to. But seams quite thick? Has anyone used it
Posted 04 October 2022 - 10:04 PM
I think I might head down the inner tube route to gauge whether that will work.
Posted 04 October 2022 - 10:07 PM
Posted 05 October 2022 - 10:35 AM
I had a thunk.
If you're improvisin, rim tape would be an even better pinch from bike bits than an inna toob.
Posted 06 October 2022 - 07:52 PM
The link to the stuff in minispares is what I looked at but looks way too thick. I saw a YouTube video of an Australian guy using what looked like tape but was essentially thin rubber. I googled it and it was ridiculously expensive.
Yeah I thought that as I have a length for another job. I had a look on the MK1 forum and found someone using this sort of stuff but he recommended 8mm wide, 5mm internal width and 10mm overall height. This is all I can find atm. https://www.ebay.co....:Bk9SR976u-31YA
Posted 07 January 2023 - 05:42 PM
I started this job today, I bought the closest size I could to the above dimensions but is too wide being 9mm wide. I then had a quick search and found this video on youtube which they use glass setting tape. This is the only company in the UK that I could find that sells it. https://www.crlauren...07&ModelID=1679
