Retrosport Engine Steady Thermostat Kit On Jdm Spi
14 replies to this topic
#1 ultimax5
ultimax5
  • 23 posts
Posted 06 October 2022 - 02:52 PM
Hi Mini Enthusiasts,
Has anyone successfully fitted any of the Retrosport (DSN Classics) Engine Steady Thermostat Kits to a JDM SPI (with coil pack) with A/C? Since the alternator sits pretty high up the engine, I was told that the outlet of the thermostat housing won’t be able to clear the bracket holding the alternator. The standard JDM SPI (with coil pack) has its thermostat housing outlet faced towards the right (if you’re facing the car), so it clears the alternator bracket that’s mounted to the cylinder head.
Any thoughts/suggestions/pics of your setup?
Thanks in advance.
#2 nicklouse
  • 18,600 posts
Posted 06 October 2022 - 05:48 PM
Can’t think what a JDM SPi set up looks like post a few clear pictures then we can advise.
there may be interesting ways to make it work.
#3 ultimax5
ultimax5
  • 23 posts
Posted 07 October 2022 - 03:13 PM
Thanks for your reply, nicklouse.  I'll try to upload some pictures this weekend.
#4 ultimax5
ultimax5
  • 23 posts
Posted 09 October 2022 - 11:18 AM
Here's a link to some pictures of the engine bay (hope it works).  You can see how the thermostat housing outlet is directed away from the alternator bracket, as standard on the JDM SPI with A/C.  The Retrosport Engine Steady Thermostat Kit (link below) appears to have the outlet facing forward, which would probably foul against the alternator bracket.
https://photos.app.g...D2Ur4VUwBUy1kV8
https://www.dsnclass...e-engines-long/
#5 KTS
KTS
  • 2,435 posts
Posted 09 October 2022 - 11:22 AM
looks unlikely it will fit given the product details on the DSN page includes the following:
Not suitable for cars with twin carbs or Japanese spec Spi models.
#6 ultimax5
ultimax5
  • 23 posts
Posted 09 October 2022 - 11:48 AM
I wrote to DSN to ask. They told me that although it’s stated in their website that it’s not suitable for Jap spec SPI models, they do sell alot of those engine steadies to Japan, so he believes that they’ve gotten it to fit somehow. I was hoping someone here might have one installed, perhaps after some modifications.
#7 Steve220
Steve220
  • 5,049 posts
  • Local Club: BMC
Posted 09 October 2022 - 11:51 AM
I was told the same and ended up having to send it back. I've got an MPi with a side mounted radiator to go in my van and can't find anyone that makes an alloy thermostat housing apart from Specialist components for their supercharged builds. However, they never reply to any of my emails.
#8 ultimax5
ultimax5
  • 23 posts
Posted 09 October 2022 - 12:03 PM
Looks like I’ll have to search for an alternative. Anyone managed to install a top left engine steady for their JDM SPI (with coilpack)?
#9 whistler
whistler
  • 1,796 posts
Posted 09 October 2022 - 03:27 PM
Suggest you look at a water pump to bulkhead steady bar as sold by Moss Europe.
https://www.moss-eur...kit-abr024.html
#10 ultimax5
ultimax5
  • 23 posts
Posted 10 October 2022 - 01:11 AM
Thanks whistler. I’ll check it out.
#11 gav
gav
  • 698 posts
Posted 10 October 2022 - 08:29 AM
MSSK1304 - Mini engine stabiliser water pump to bulkhead kit with bushes (minispares.com)
#12 whistler
whistler
  • 1,796 posts
Posted 10 October 2022 - 09:47 AM
Same as the Moss-europe one. There's also one on ebay but I think the plate metal is thinner.
I fitted one to my wife's 1330 and also one is going on my Mk1 Hydro (with a modified base plate) as nobody makes one for the Hydro suspension models.
#13 Maccmike8
Maccmike8
  • 1,101 posts
Posted 10 October 2022 - 10:13 AM
The alty is the problem, I suspect its the amount of pipes and cables on the bulkhead, find a gap and Im sure youd get the DSN one to fit.
#14 gav
gav
  • 698 posts
Posted 10 October 2022 - 12:17 PM
I know, just cheaper if you use your TMF+ ;)
#15 ultimax5
ultimax5
  • 23 posts
Posted 10 October 2022 - 12:24 PM
It’s the angle of the DSN thermostat housing outlet that I foresee to be a problem. The alternator bracket is right in front of it.
