Piston Choice Std Dimension
8 replies to this topic
#1 Java_Green
Java_Green
  • 176 posts
Posted 07 October 2022 - 06:35 AM
I am building a supercharged A+ engine and looking for advice considering choice of pistons. Since I am about to put in new cylinder liners I would prefer STD dimension, i.e. 70.60 mm in diameter. The aim is approximately 9.5:1 in compression ratio with a compression chamber volume of 23cc, so some dish is needed.
#2 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 07 October 2022 - 07:27 AM
I'm not sure about classic mini cylinder liners, but on bigger blocks if they're press fit, they need to be bored and honed anyway - Do they come undersized to bore to 70.60? You are severely limited yourself to piston choice at 1275, at 1293 (+20) you open yourself up to both cast and forged options. As well as lowering your CR with size alone.
9.5 CR is quite high for boosted - why have you chosen that?
#3 mini13
mini13
  • 3,811 posts
Posted 07 October 2022 - 07:53 AM
the liners are basically at 1275 size, but they will at least need a hone, and probably a light bore
also bigger bore will raise the compression not lower it
https://westwoodcyli...0-1380-engines/
#4 Java_Green
Java_Green
  • 176 posts
Posted 07 October 2022 - 09:01 AM
I know that 9.5 in CR is considered as high for a boosted engine. My guess is that a CR of 9.1-9.5 is suitable for the application and set up (other opinions and knowledge is more than welcome). This is roughly my thoughts; the ERA run a CR of 9,4 and with a fairly similar combustion chamber design, about the same boost level, ECU controlled ignition and fueling (X-flow head with injector in each runner), with a better heat dissipation (Aluminium head) and lower intake temperature (in the front and not "turbo heated").
#5 Java_Green
Java_Green
  • 176 posts
Posted 07 October 2022 - 09:17 AM
I am thinking that the liners needs to be bored out to 70.60 mm (std dimension) when fitted into the block. It would be good to not go for +20 directly as that would make it possible to at least rebore the block once without replacing the liners.
#6 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 07 October 2022 - 11:45 AM
Yep, you're right. Had a mind fart this morning
#7 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 07 October 2022 - 11:46 AM
Oh, you're going 7 port?
#8 Java_Green
Java_Green
  • 176 posts
Posted 08 October 2022 - 09:53 PM
That is correct!
7-port it is... Front mounted supercharger feeding a plenum from where a runner goes to each port.
#9 Steve220
Steve220
  • 5,066 posts
  • Local Club: BMC
Posted 09 October 2022 - 09:34 AM
Ah, you'll be fine with a high CR then. The alloy will help remove the heat from the combustion process better and you'll have greater control over fueling. I've got 9.5 and full send! Although, be careful if you're not running an intercooler/chargecooler, inlet temps can rocket!
