Stuck Fuel Cap
Best Answer sarboykay , 11 October 2022 - 08:04 AM
The key (I've only got one) only turns very slightly even after a night of oil soaking. I'll give it a while and then try the hammer approach, luckily I always fancied an Aston style filler...
Go to the full post
5 replies to this topic
#1 sarboykay
sarboykay
    Just On Tickover
  • 7 posts
Posted 10 October 2022 - 03:49 PM
Hi all
So after 18 months on axle stands, I'm finally getting round to sorting the spi's cones and knuckles. Front done and as I start on the rear, I thought I'd do the fiddly one first and move the fuel tank to do so. But I can't get the key-operated fuel cap off; the lock won't rotate at all. I've loaded the lock with penetrating oil and will give it a day or so.
If it's stuck completely, has anyone got any ideas that don't involve me setting fire to myself?
#2 Steam
Steam
  • 822 posts
  • Local Club: Victorian Mini Club
Posted 11 October 2022 - 12:18 AM
As you have done with a lubricant and work it with the key. You may get lucky and it starts to move.
Worst case, use a suitable rod or punch on the key lock area and a goodly sized hammer and belt the lock innards into the tank. The remnants can be removed through the sender hole.
#3 MikeRotherham
MikeRotherham
  • 987 posts
Posted 11 October 2022 - 07:41 AM
Does the key turn at all or is it that you can't rotate the cap?
If it's the lock itself, is the key worn can you try the other if you have two?
Edited by MikeRotherham, 11 October 2022 - 07:43 AM.
#4 sarboykay
sarboykay
    Just On Tickover
  • 7 posts
Posted 11 October 2022 - 08:04 AM   Best Answer
#5 sarboykay
sarboykay
    Just On Tickover
  • 7 posts
Posted 13 October 2022 - 12:58 PM
Sorted after three days of squirting engine oil into the lock with a syringe!
#6 Steam
Steam
  • 822 posts
Posted 14 October 2022 - 03:46 AM
Excellent, Result. May I suggest a new locking cap, if the old one has stuck once it is likely to do so again. A new cap would be cheap insurance.
