Motorbike Trickle Charger
7 replies to this topic
#1 Yoda74
Yoda74
  • 58 posts
Posted 10 October 2022 - 05:44 PM
Hi,
When my mini is parked in my garage for some time I always connect the battery to a trickle charger.
The charger shows green lights, so theoretically the battery should be charged and allright.
But often the starter has trouble turning the engine when it has been on the trickle charger (and the engine is cold)
after driving it and parking it and starting it again (with warm engine) the starter has no trouble turning the engine.
the trickle charger I originally bought for my motorbike, a long time ago.
can it be that the charger is not up to charging a car battery or should that make no difference?
cheers,
#2 cal844
cal844
  • 9,636 posts
  • Local Club: TFMOC
Posted 10 October 2022 - 05:46 PM
Is it a 12 volt battery charger?
#3 Yoda74
Yoda74
  • 58 posts
Posted 10 October 2022 - 05:51 PM
Ofcourse !
#4 beardylondon
beardylondon
  • 1,600 posts
Posted 10 October 2022 - 07:38 PM
Yes, I use my motorbike one for my minis.
Hi,
cheers,
#5 nicklouse
  • 18,661 posts
Posted 10 October 2022 - 07:44 PM
Check the battery it could still be duff. Also check your connections to the battery and the earths.
#6 Yoda74
Yoda74
  • 58 posts
Posted 11 October 2022 - 10:28 AM
When the connections are bad, shouldn't the starter always have trouble turning the engine?
#7 Ethel
  • 26,029 posts
Posted 11 October 2022 - 10:39 AM
The starter circuit is a sum of its parts. The resistances add up & if they cause enough voltage drop so the motor doesn't spin it has a low resistance that will make all those resistance hot spots even hotter & drain the battery even more.
#8 unburntfuelinthemorning
  • 1,987 posts
Posted 11 October 2022 - 04:10 PM
A cold engine is always harder to turn over than a warm engine so a cold engine will always exacerbate battery and connection issues.
