I bought an old intake manifold and the HIF44 spacer-to-manifold surface has a couple of nicks (someone used a small screwdriver to separate two). Perhaps the gasket might do the job to seal the mating surfaces but to be sure I want to repair it. I don't have aluminum welding capability so my two choices are something like JB Weld for aluminum or simply a silicone based sealant like RTV. Any thoughts?
Intake Manifold Repair
croc7
, Oct 21 2022 10:41 PM
3 replies to this topic
Posted 21 October 2022 - 10:41 PM
Posted 22 October 2022 - 12:33 AM
JB will do the trick easily
Posted 25 October 2022 - 06:52 AM
Went for a JB Weld repair w/Hylomar Blue on the spacer’s gasket. Probably a bit of overkill. Belts and braces.
Posted 27 October 2022 - 07:25 AM
studs out to get at the face, and give it a flash over with a bit of Wet & Dry this will show iif theres any high spots, and how far the nicks go toward the carb hole. If youve got a solid 5mm or so band around the hole for the gasket to seal on I wouldnt bother trying to fill it
