Mini Clicks When Turning Ignition And Battery Doesn’T Hold Charge
5 replies to this topic
#1 Rovobor
Rovobor
    Starting My Mini Up
  • 1 posts
Posted 22 October 2022 - 07:24 PM
Hey all,
I’ve recently taken on a Mini Mayfair 1992. When I try to start it, it just clicks even when trying to jump start it. The battery seems to drain, anything ideas?
Any other general advice for a non mechanic as well?
Thanks!
#2 nicklouse
  • 18,998 posts
Posted 22 October 2022 - 08:41 PM
Dead battery, dead alternator.
#3 red81
red81
  • 63 posts
  • Local Club: Pembrokeshire Mini Club
Posted 25 October 2022 - 06:13 PM
If it just clicks and doesn't turn the engine it could be a stuck solenoid, try a screw driver across the two connectors on top of the solenoid. Battery not holding its charge Nick has the two options unless you have something draining the battery e.g bulb or CD player permanently on.
#4 Clip
Clip
  • 185 posts
Posted 27 October 2022 - 08:02 AM
Swap out old battery with one that you know is ok as jump starting can be notoriously unreliable. If still not starting, check positive cable on starter solenoid and earth cable on battery (but unlikely if it is clicking in).
#5 Ethel
  • 26,580 posts
Posted 27 October 2022 - 08:43 AM
Won't work on a pre-engaged starter, unless you engage the solenoid first. Unlikely it'll work even if you - the clicking is the solenoid falling out as soon as the motor is engaged because there's not enough oomph from the battery.
#6 Ethel
  • 26,580 posts
Posted 27 October 2022 - 08:56 AM
The battery is defo suspect. If it has an internal short  the jumper battery could be boiling it rather than spinning the motor.
Like Clip says, a known good battery will allow fault checking of the other components at least...
Headlight brightness is a rough & ready general indicator of faults in the battery connections - as is the indicator flash speed if it has an old school flasher unit.
