Mpi Aux Belt Sqeak
Posted 23 October 2022 - 10:03 PM
I have a persistent aux belt squeak which I can't shift on an MPI and would welcome ideas. I have changed the belt twice and it keeps squeaking.
Could one of the pulleys be out of alignment? Anyone else had similar?
For reference the water pump was changed for a high capacity version and the tension pulley replaced just before I got it back on the road a couple of years ago.
Posted 30 April 2023 - 03:42 PM
Further on this topic I posted some time ago, I have found my alternator pully is 5mm offset (towards the engine) from the water pump and crankshaft pullies, which are roughly in alignment. Poly-v belts are more sensitive to pulley alignment and this could well be the root cause of my belt squealing.
I think the alternator has been replaced at some time in it life. From what I can gather the alternator on an MPI is fixed so the only other option is to remove the pulley and pack it somehow.
Anyone else with/had a similar issue?
Edited by Deeppockets, 30 April 2023 - 04:23 PM.
Posted 30 April 2023 - 04:38 PM
Posted 11 April 2024 - 04:58 PM
(Some time later...)
Thanks Sonscar, that was a good suggestion. The alternator did have a floating rear bush which would have allowed the front mounting points to be packed forward with washers.
In the end, however, I obtained an original Marelli alternator (in really god condition) which I have fitted - and squeak gone! The removed alternator is an aftermarket unit but with no identifying markings.
Putting the two units together on the bench the aftermarket unit's brackets-pulley distance is shorter than the OEM.
Posted 11 April 2024 - 07:26 PM
Posted 15 April 2024 - 09:38 PM
