This might be a difficult one to explain, but I will try. If recording a youtube video would help, I'm happy to do that.
Car: 1991 Japan Spec Mini 1000cc
Problem:
- First off, I had to remove the clocks to gain access to the dash in order to do some repairs. I took the clocks apart to clean them, and they all went back together just fine.
- Taking apart the clocks was also an attempt to see why the tach doesn't work, it never did since I got the car
- Re-assembling the dash surfaced a few issues:
- I noticed the lights on the cluster aren't working anymore
- The 'flasher' cylinder has 2 green wires going into it, and one green wire going into the tach
- Turning the car on, the tac was working for a couple of minutes, but then didn't again
- I think I got the 3 green wires mis-matched (one goes into the back of the tach, the other 2 go into the cylinder)
- I tried to look at the wiring diagram, but I'm really confused trying to parse that....
- Does anyone know which order the 3 green wires go in? 2 of them are green/brown, and the other one is a solid green wire
But this raises a somewhat related issue:
- headlights have always worked intermittently
- looking at the fuse box, the bottom right connection doesn't have anything plugged into it
- I can't see any wires in the engine bay that *would* plug in there
- the inline fuses of the wires that go into the box are OK
- would this fuse not being connected have any relationship to these issues? (tach, headlights, cluster lights)?
Attached are a few photos showing the issues
Gallery is also located here: https://imgur.com/a/BEP5S24
