Led Tails Bulbs Weird Problem
Posted 27 October 2022 - 12:16 PM
Posted 27 October 2022 - 01:17 PM
That would typically be an earthing problem. The current from lights in question would use the other lights attached at the unearthed earth points to find another earth
It may be down to your led bulbs though. Are they replacements for the original twin filament stop/tail bulbs? . Adding resistance before one of the leds could make the voltage higher on the shared earth than between the resistor you added and the, brake led.
Posted 27 October 2022 - 06:10 PM
For Brake Lights, you shouldn't need any load resistors. They are normally only used on Indicators as some Flasher Cans need load in order to flash.
As Ethel suggests above, the issue here sounds to me like bad earths on your rear lamps.
Posted 27 October 2022 - 10:09 PM
Posted 28 October 2022 - 11:24 AM
