Wiper Stalk Wiring
3 replies to this topic
#1 Straker Junior
Straker Junior
  • 34 posts
Posted 28 October 2022 - 07:00 PM
I currently have my column stalks off the car. It is a bare shell rebuild and I will be making a new loom. So I have these on the bench with a 12v battery and a multi meter making a note of what each wire does.
I have 99% figured out all the wiring but am stuck on a loose black wire and the washer wiring.
There is a green/black wire coming out of the washer stalk. But of course when pressing this it needs to make a circuit and one wire can’t do that on its own. So I figured that when you press the stalk it competes a circuit, the final bit of the circuit perhaps being an earth?
But if the power gets to the stalk via the solid green wire, then I am not sure how the 12v supply gets to the washer stalk.
The loose black wire in the picture would make sense to earth to the column itself correct?
However, I was confused as this is sharing a connector with a green wire which I understand to be the 12v power source to that stalk. When I feed 12v to the stalk via the solid green wire, the black wire reads 12v too of course.
Where do I connect that black wire please?
And what is it that competes the circuit when I press the washer button?
Thanks in advance
Jeremy
#2 Straker Junior
Straker Junior
  • 34 posts
Posted 28 October 2022 - 07:04 PM
This is whart I have established so far:
Solid Green - 12v in to stalk (black wire also comes off the green terminal and reads 12v)
Red/Green - wiper speed 1
Blue/Green - wiper speed 2
Brown/Green - park???? not sure how this works though
Black/Green - washer (but given only 1 wire runs up the stalk I am not clear how to complete the circuit)
Edited by Straker Junior, 28 October 2022 - 07:04 PM.
#3 mini-mad-mark
mini-mad-mark
  • 860 posts
  • Local Club: northants wot no brakes
Posted 28 October 2022 - 08:16 PM
Assume you have the wiring diagram in front of you? If not then that's probably a good place to familiarise yourself
The washer makes its circuit to earth after the pump so it is ignition switched live to the stalk (light green/orange - feeds the wipers AND washer) then live FROM the stalk to the pump (light green/black) then from pump  to earth black - this bit:
Attached File  Capture1.JPG   21.93K   0 downloads
Not sure why you have solid green instead of light green/orange - can't really answer that as must be something different with your loom
This is quite a good explanation of the operation of the wipers including how the park is achieved:
http://www.mgb-stuff.org.uk/wiper3.htm
Although its MGB really its a lucas wiper set up on a BL car.....
#4 Straker Junior
Straker Junior
  • 34 posts
Posted 28 October 2022 - 08:36 PM
Thank you. I have looked at various wiring diagrams but my colours didn’t tie up well. I will work through this slowly in the morning. Appreciate the advice.
