Radius Arm Grease Nipple Access
8 replies to this topic
#1 Clip
Clip
  • 185 posts
Posted 07 November 2022 - 12:50 PM
Been meaning to ask this question before. To access the grease nipple on both the radius arms (left and right), I have to remove the shrouds. The arms sit too high above the grommet hole making it impossible to get to the grease nipples. Is there something wrong with my rear subframe? It looks fine and the car handles fine, but just concerned something not correct.
#2 colinf1
colinf1
  • 1,033 posts
Posted 07 November 2022 - 01:08 PM
Could the shroud be damaged? IIRC its only held in place with 2 screws.
A picture would help determine any potential subframe issues..
#3 nicklouse
  • 18,741 posts
Posted 07 November 2022 - 03:52 PM
Adjustable brackets fitted?
#4 mab01uk
mab01uk
  • 12,604 posts
Posted 07 November 2022 - 06:37 PM
CAMBER BRACKETS REAR ADJUSTABLE
https://www.minispar...assic/MS70.aspx
NEGATIVE CAMBER BRACKETS REAR FIXED
https://www.minispar...assic/MS69.aspx
When negative camber brackets are used they move the outer radius arm pivot and grease nipple upwards from the standard factory position.
Edited by mab01uk, 07 November 2022 - 06:41 PM.
#5 Clip
Clip
  • 185 posts
Posted 07 November 2022 - 11:11 PM
Yes, it has the adjustable type. So no need to worry then?
Edited by Clip, 07 November 2022 - 11:26 PM.
#6 MikeRotherham
MikeRotherham
  • 992 posts
Posted 08 November 2022 - 05:20 PM
I've never seen shrouds in such good condition
Later cars never had them fitted.
Edited by MikeRotherham, 08 November 2022 - 05:23 PM.
#7 Clip
Clip
  • 185 posts
Posted 08 November 2022 - 09:06 PM
I’m only the third owner, so guessing they’re the originals which means they’re only 60 years old this year.  :D
Edited by Clip, 08 November 2022 - 09:07 PM.
#8 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 09 November 2022 - 10:27 AM
you can buy new ones,
14A6615 - Mini radius arm shroud r/h (minispares.com)
#9 whistler
whistler
  • 1,837 posts
Posted 09 November 2022 - 05:34 PM
You could fit angled grease nipples.
