In the true sprit of fixing things that aren’t broke. I’ve recently switched my 382 indicator bulbs to leds, unfortunately even though I’d previously fitted electronic flasher relays for both the indicators and hazards nether worked (hyper flashing) with the lower current draw from the leds (Was kind of expecting it to be honest).
So I’ve since bought and fitted a pair of replacement led flasher relays for both the hazards and indicators, so both now flash at the correct rate.
My issue now is, the new indicator relay mounted behind the dials is too quiet to be heard over the engine while driving. My old electronic flasher relays had a nice load addable tick, tock,/clicking.
As I’m not too fused about how audible the hazards are, would it be possible to use a standard 30amp 4 pin relay (with audible clicking) and wire (piggy back connectors) pin 86 to the solid green wire on the flasher relay and pin 85 to earth (the new relays use an earth anyway)?
Or would I have to wire pin 86 to green and pin 85 to light green and brown, so across the flasher relay?
And leave the other 2 pins of the relay unused (I have some pre wired relay pugs so I could just remove the unneeded wires).
Edited by 1984mini25, 10 November 2022 - 06:28 PM.
