What Spark Plug Gap Modified 998, Electronic Ignition.
2 replies to this topic
#1 humph
humph
    How bad can it Be?
  • 1,101 posts
Posted 15 November 2022 - 11:58 PM
My Haynes manual says spark plug gap of 0.032 inch (0.8mm) for electronic ignition, but have seen various sources saying up to 0.050 inch. I have a 998 with the following spec that is and was wondering what gap people would recommend for this spec. I’m currently at the 0.032 inch, just not sure if it’s modded enough to need something else.
998cc A+ block - Bored to 0.060" & skimmed
Compression ratio 10.5:1
Crank - 998cc Re-ground
Head - 12G295 skimmed by 0.050"
Pistons - P-22463 +0.060" Flat Top
Cam - Minispares Evolution001
Timing chain - 3H2127EVO timing chain (simplex)
Final Drive - 3.44
C-AEG421 4.48kg Lightened Flywheel
HIF38 Carb
MS stage 1 kit with K&N in a Vizard modded original airbox
Distributor - As recommended by MS to go with cam http://www.minispare...|Back to search
Spark plugs - BP6RES
Coil - GCL143 As recommended by MS for the dizzy
thanks
#2 unburntfuelinthemorning
  • 1,985 posts
Posted 30 November 2022 - 10:17 PM
I'd say stick to the Haynes manual suggestion of 32 thou as you have the coil for electronic ignition.
#3 timmy850
timmy850
  • 3,353 posts
  • Local Club: MITG
Posted 30 November 2022 - 10:45 PM
If you’ve got a 0.9 ohm coil and no ballast you can run a fairly wide gap as that’s a lot of coil power
