No Ignition Lights
4 replies to this topic
#1 cotty
cotty
  • 60 posts
Posted 16 November 2022 - 09:31 AM
hi guys my fault i have connected dizzy to the wrong side of the coil and now i have no ignition lights,i have checked the fuses in the engine bay they are ok anybody got any ideas?
#2 Clip
Clip
  • 185 posts
Posted 17 November 2022 - 04:55 AM
Done that plenty of times and never had a problem once swapped them over. You haven’t just got a bad connection, or maybe another join that’s pulled out when messing around with them?
#3 Mr Piggy
Mr Piggy
  • 58 posts
Posted 19 November 2022 - 11:38 PM
It's actually a generator light and has nothing to do with the ignition. It just comes on when you switch the ignition on, before you start the engine because it's not charging the battery.
It's possible that you've overloaded the power supply to the coil and blown the balast resistor. You need to disconnect the live feed to the coil and test if you have power there, preferably with some load. I use an old headlamp bulb as a test light to ensure the connection is capable of passing a decent amount of current.
That doesn't explain why you've lost your gen light though. It could be a coincidence but could be linked if you have damaged the ignition switch or comon output wiring from the switch.
The ignition system should not be fused.
The gen light probably is and will likely be on the same circuit as the fuel and temp gauges. If they are still working, first call is check the gen light bulb and power there. It's fed from the ignition switch, probably via a fuse, and earths through the alternator.
Good luck!
#4 cotty
cotty
  • 60 posts
Posted 23 November 2022 - 08:56 AM
thanks for that the mini is a 1992 i cant find a ballast resister anywhere,i have bought a new ignition switch and voltage stabilizer fingers crossed ?
#5 Retro_10s
Retro_10s
    Moderator
  • 10,139 posts
Posted 23 November 2022 - 08:56 PM
The ballast resistor is a thick pink/white wire in your wiring harness, that attaches to your coil
