Which Magnetti Marelli Pick Up For Megajolt
5 replies to this topic
#1 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 18 November 2022 - 09:47 AM
This an older type Megajolt from 10 yrs ago MJLJ as I recall. I need to renew the trigger wheel pickup.
When I did it all I'm sure there were several makes and types listed on Autosports' site.
Can anyone help by directing me there so I know the part number.?
Thank you
#2 Ethel
  • 26,088 posts
Posted 18 November 2022 - 01:09 PM
It connects to the Edis, I just pulled to one from the donor Ford. I think the one used by a lot of the kits is the same as Cosworth, but I imagine pretty much any hall effect crank sensor should work.
#3 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 18 November 2022 - 05:43 PM
I think they will Ethel, I'm sure you're right.
I thought I'd take the easy route if poss to avoid having to make another bracket
Annoyingly my local motor factor probably have it on the shelf, they did last time but without a number these guys are hopeless.!
#4 PoolGuy
PoolGuy
  • 858 posts
Posted 18 November 2022 - 07:26 PM
They generally run the Magnetti Marelli SEN8D
#5 Pigeonto
Pigeonto
  • 973 posts
  • Local Club: ISMOC
Posted 18 November 2022 - 08:14 PM
Mate, you've cracked it. I remember now.!!
Well done, much appreciated, thankyou.
Hopefully it's not a discontinued line
#6 PoolGuy
PoolGuy
  • 858 posts
Posted 18 November 2022 - 10:09 PM
MED and others sell it https://www.med-engi...-management/cps
