Drums Only. 12 To 10 Wheels
11 replies to this topic
#1 Cyclops63
Cyclops63
  • 82 posts
Posted 25 November 2022 - 01:40 PM
Hi, and apologies if this is elsewhere but all I can find are posts about this disc setup and that disc setup. I have a 79 saloon. It's an 850. I don't need discs. It currently has 12inch wheels. Question: Can I simply replace these with 10inch wheels? Just plain steel wheels, I'm not interested in anything fancy. So, 10inch steel wheels on '79 drums?
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,043 posts
Posted 25 November 2022 - 01:50 PM
Yes, all 10" wheels will fit over drums. There may be a chance you'll need spaced drums on the back as they may hit the shocks.
#3 Cyclops63
Cyclops63
  • 82 posts
Posted 25 November 2022 - 02:24 PM
#4 Gilles1000
Gilles1000
  • Just Joined
  • 438 posts
Posted 25 November 2022 - 02:33 PM
Yes, that will work. The original Mini came with drums and 10" steelies on the market.
Be careful not to have the Cooper S steelies, as they have a different offset and may touch the body.
The Reverse rims (LP918?) are OK tough, as they were designed for Cooper models.
#5 Cyclops63
Cyclops63
  • 82 posts
Posted 25 November 2022 - 02:45 PM
Thank you, Gilles for the prompt, succinct response 😀
Edited by Cyclops63, 25 November 2022 - 02:45 PM.
#6 mab01uk
mab01uk
  • 12,571 posts
Posted 25 November 2022 - 06:09 PM
All 1979 Minis with drum brakes came with 10" wheels from the factory. At that time only the 1275GT had disc brakes and 12" wheels.
See 1980 Mini Brochure here:-
(scroll down)
http://www.minipassi... range 1980.pdf
(Cooper S and early 1275GT had smaller disc brakes which fit 10" wheels).
Edited by mab01uk, 25 November 2022 - 06:10 PM.
#7 Cyclops63
Cyclops63
  • 82 posts
Posted 26 November 2022 - 10:46 AM
Cheers Mab
#8 Cooperman
  • 23,340 posts
Posted 26 November 2022 - 05:27 PM
You must get wheels with the correct datum offset.
Cooper 'S' wheels will not fit.
#9 Cyclops63
Cyclops63
  • 82 posts
Posted 26 November 2022 - 07:02 PM
Thanks. I dont want Cooper wheels anyway. Just bog standard 😀
#10 Steam
Steam
  • 842 posts
  • Local Club: Victorian Mini Club
Posted 27 November 2022 - 01:16 AM
And some tyre brands can rub at the rear, they must baloon out more than others.
#11 Cooperman
  • 23,340 posts
Posted 27 November 2022 - 02:38 PM
You will always be ok with a 145x10 tyre, which is all you need on a drum-braked Mini.
#12 PACINO
PACINO
  • 775 posts
Posted 27 November 2022 - 03:08 PM
you showed up Cooperman! We thought you would have died or something
